New to Plusnet and some help required.
- New to Plusnet and some help required.
23-03-2013 5:50 PM
Looking for a bit of help,
I have recently transferred over from BE to Plusnet and have just had FTTC installed. All is set up and working fine.
However........
I should have in the next few days a FRITZ!Box 7390 and would like replace the BT supplied modem and Plusnet supplied router.
For those that have the FRITZ!Box can someone point me in the right direction of the required settings and how this needs to be set up?
Any help that can be provided would be appreciated. I did a search of the forum but could not find anything that would assist.
Many Thanks.
Re: New to Plusnet and some help required.
23-03-2013 7:35 PM
24-03-2013 12:03 AM
It can either be connected to the OR modem or, as I do, direct to the VDSL line. For this you need to set (Internet > Account Information page) Connection, select 'Connecting to a DSL Line', Account Information, Is account information required? Select 'Yes' and enter your plusnet username ???@plusdsl.net and your password. Then click on 'Change connection settings' and under 'Internet Connection ' select 'Maintain permanently (recommended for flat rates) ', tick the 'Use VLAN' box and enter 101 as the VLAN ID, under 'DSL ATM Settings' select 'Set manually', leave 'VPI' set to 1 and 'VCI' set to 32 but ensure that you select 'PPPoE' under 'Encapsulation' (this setting will 'disappear' if you go back to this section and you will need to re-select it - it's a bug in the firmware), finally tick 'Check the Internet connection after "Apply" has been clicked ' then hit the 'Apply' button after which you'll get a couple of dialogue boxes (can't remember exactly what they say but pretty obvious stuff).
26-03-2013 7:59 PM
Many Thanks for the help !
27-03-2013 7:32 AM
If you need (or want) to connect the FB to the OR modem via EWAN it's recommended that you factory reset the FB and start the configuration afresh.
Glad the instructions were good.
03-06-2013 2:10 PM
Just a thought, but is 'username@plusdsl.net' correct for FTTC?
03-06-2013 6:37 PM
11-12-2013 4:31 PM
Regards
Ian
11-12-2013 4:51 PM
